Hello! When importing a large number of documents, what does the following line mean?
INFO paperwork_backend.docimport Document file:///home/josh/Documents/IncomingScanned/9.06.pdf already found in the index. Skipped
Does it mean that a document with the filename 9.06.pdf is already in the index? Or, does Paperwork do a checksum of the PDF file when it imports, and then check to see if that checksum is already in the database?
If it’s a filename rather than checksum then I may be in trouble. I do a huge number of scans in batches- so I may have files name 01.01.pdf to 12.01.pdf to 01.15.pdf to 10.15.pdf, and then I’ll import those and delete them from the IncomingScanned directory- then the next time I do batch scanning I’ll have repeats of the same filenames. Maybe that wasn’t such a good idea…
