Selecting text from imported document
is it possible (and how) to select / copy text which has been imported in PAPERWORK?
Let me explain my scenario: I import a document, then some text is recognized. I want to copy it to paste it. But, as I try to select it, it shows me the text, but doesn’t grant me the possibility to copy.
The present workaround is to export it as a pdf and copy it then. But I don’t need the exported pdf and find useful to just have a single place (PAPERWORK) that classify my documents.
Is there a more direct and simple workaround?
To select the text, you must first make sure the view is set to list (instead of grid). It’s the default view if there is only one page in the document. Else you can simply click on a page to select it and switch the view. Otherwise you can use the option at the bottom left:
Then you can select text with your mouse left button.
To copy the selected text, at the bottom right of the main window, there should be an option to copy the selected text.
Ctrl-C should work too.
solved, thanks.
