Scanner not found
Ther scanner is not found
there is some about written but all with out success
also that i must install daned it was already installed !
udo apt install sane-utils
sudo sh -c “echo 127.0.0.1 >> /etc/sane.d/saned.conf”
sudo systemctl enable saned.socket
sudo systemctl start saned.socket
sudo adduser saned plugdev
sudo adduser saned scanner
sudo adduser saned lp
reboot
all not with success - it is so difficult to make it ready for san ?
XSANE using and other Scaner are working ready with HP laserjet in the network
https://www.openpaper.work/en/download/linux#openpaper_flatpak
Unfortunately, due to containerization, it cannot be used with network scanners yet. Using it with local scanners may require a bit of tweaking.
