Hi, I need some help. My Windows 10 PC became unbootable and I had to clean install Windows. I do have a backup of my previous system. How can I reinstall Paperwork and get all my scanned docs with labels back to the way it was? I’m not finding much in the way of a manual for the program. Thanks!
You simply need to restore the work directory of Paperwork.
Then you can simply point Paperwork towards it,
and wait for it to rescan it.
Thanks, that was easy!
