Good evening,
after installing Paperwork on a different laptop, also running Arch Linux, it starts well, I can import existing png or jpg files, but I can’t scan. It starts the scan, but the live preview stays a blank page until the whole program crashes.
I startet paperwork from the commandline in order to get the error message. This seems to be the relevant part:
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] …/libinsane-1.0.10/subprojects/libinsane/src/bases/sane.c:L520(lis_sane_item_get_scan_parameters): brother4:net1;dev0->sane_get_parameters() returned: format=1, height=2322, width=1648, bytes_per_line=4944, depth=8
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] …/libinsane-1.0.10/subprojects/libinsane/src/bases/sane.c:L550(lis_sane_item_get_scan_parameters): Image format: 0
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] …/libinsane-1.0.10/subprojects/libinsane/src/bases/sane.c:L551(lis_sane_item_get_scan_parameters): Image WxH: 1648x2322
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] …/libinsane-1.0.10/subprojects/libinsane/src/bases/sane.c:L552(lis_sane_item_get_scan_parameters): Image size: 11479968
[INFO ] [paperwork_gtk.mainwindow.docview.scanview] Scan size: 1648x2322
[INFO ] [paperwork_gtk.mainwindow.docview] Going to page 0 (nb pages=1)
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] ======== PID 65840 - SEGMENTATION FAULT ========
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] ======== START OF BACKTRACE ========
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/libinsane.so.1(+0x14b00)[0x7fa59ca40b00]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/libc.so.6(+0x3e710)[0x7fa5a125c710]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/sane/libsane-brother4.so.1(make_cache_block+0x3c9)[0x7fa58de25fba]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/sane/libsane-brother4.so.1(read_scanned_data+0x10b)[0x7fa58de24d62]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/sane/libsane-brother4.so.1(PageScan+0x5af)[0x7fa58de1408c]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/sane/libsane-brother4.so.1(sane_brother4_read+0x4b)[0x7fa58de1c6c4]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/libinsane.so.1(+0x19264)[0x7fa59ca45264]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/libinsane.so.1(+0x64e2)[0x7fa59ca324e2]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/libinsane.so.1(+0x176eb)[0x7fa59ca436eb]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/libinsane.so.1(lis_worker_main+0x1ef)[0x7fa59ca4754f]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/libinsane.so.1(lis_api_workaround_dedicated_process+0x3be)[0x7fa59ca47ade]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/libinsane.so.1(lis_safebet+0x1f1)[0x7fa59ca3fbb1]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/libinsane_gobject.so.1(libinsane_api_new_safebet+0x68)[0x7fa59f5cb7a8]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/libffi.so.8(+0x74f6)[0x7fa5a11524f6]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/libffi.so.8(+0x3f5e)[0x7fa5a114ef5e]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] /usr/lib/libffi.so.8(ffi_call+0x123)[0x7fa5a1151b73]
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] ======== END OF BACKTRACE ========
read() failed: fd=10, r=0, got=0, expected=8; 0, Erfolg[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] …/libinsane-1.0.10/subprojects/libinsane/src/workarounds/dedicated_process/protocol.c:L315(lis_protocol_log_read): poll() failed on fd 0-12: 0x10
[ERROR ] [paperwork_backend.docscan.libinsane] [LibInsane] …/libinsane-1.0.10/subprojects/libinsane/src/workarounds/dedicated_process/master.c:L317(remote_call): session_scan_read() failed: 0x40000006, I/O Error
[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] …/libinsane-1.0.10/subprojects/libinsane/src/workarounds/dedicated_process/protocol.c:L315(lis_protocol_log_read): poll() failed on fd 1-14: 0x10
write() failed: fd=9, w=-1, written=8, expected=0; 32, Datenübergabe unterbrochen (broken pipe)[INFO ] [paperwork_backend.docscan.libinsane] [LibInsane] …/libinsane-1.0.10/subprojects/libinsane/src/workarounds/dedicated_process/master.c:L197(log_thread): Stopping log thread because: 0x40000006, I/O Error
[ERROR ] [paperwork_backend.docscan.libinsane] [LibInsane] …/libinsane-1.0.10/subprojects/libinsane/src/workarounds/dedicated_process/master.c:L306(remote_call): scan_session_cancel() failed: 0x40000006, I/O Error
Speicherzugriffsfehler (Speicherabzug geschrieben)
Details concerning my system:
ti@flipdelle:~$ uname -a
Linux flipdelle 6.6.6-arch1-1 #1 SMP PREEMPT_DYNAMIC Mon, 11 Dec 2023 11:48:23 +0000 x86_64 GNU/Linux
ti@flipdelle:~$ pacman -Q paperwork
paperwork 2.2.1-2
What can I do to solve the problem?
Thanks + best regards,
t_matze
