Good news everyone ! Paperwork 2.2.2 is out !
What’s new ?
- backend: docexport PDF: Workaround Cairo bug that causes occasional crashes when
exporting to generated PDF - backend: export: Add export pipe to export to PDF by automatically selecting the original PDF if available or generating a new one else
- backend/GTK: make it possible to edit help documents: it seems that this is actually often the first thing that people do try in Paperwork. Help documents are now copied on the fly to the work directory when edited
- backend: sklearn: Fix stuck progress bar when switching work directories
- backend: overall improvements regarding support of corrupted documents
- CLI: disable automatic paging of output. This tends to be actually more annoying than helpful
- CLI: Fix
paperwork-(json|shell) plugins show
- GTK: doc list layout: do not let a big lengthy label increase the horizontal size
of the document list.
Reminder: Pypi packages are not updated anymore.
Changelogs
As usual, detailed ChangeLogs can be found here:
- openpaperwork-core’s ChangeLog
- openpaperwork-gtk’s ChangeLog
- paperwork-backend’s ChangeLog
- paperwork-gtk’s ChangeLog
- paperwork-shell’s ChangeLog
