Basically, thanks to everybody that contributed to make this release possible. This obviously includes translators, code contributors, testers, documenters, and hopefully soon package maintainers
Wonder if it’s worth a note on the Release Notes to say that anyone using the LTS 20.04 release for Ubuntu flavors cannot upgrade to this version. The 20.04 LTS repository packages are stuck at 1.3.. The 21.04 repository has a version of 2.
I tried using the manual install method on my Kubuntu 20.04 (using git, etc.) and a dependency failed for gir1-handy-1 (the only dependency failure btw) which could not be installed due to upstream dependencies. So, I took the plunge and did a distro upgrade to 21.04 and redid the git pull, etc. process. All works well.
Hej,
I’m using a flatpak installed paperwork, and after every start paperwork says, there is a new version 2.1, but if I do a flatpak update I just get this message:
flatpak update work.openpaper.Paperwork
Looking for updates…
F: Warning: Treating remote fetch error as non-fatal since app/work.openpaper.Paperwork/x86_64/master is already installed: No such ref 'app/work.open
paper.Paperwork/x86_64/master' in remote paperwork-origin
Nothing to do.
