Is it possible to merge instances of OpenPaperwork from smaller hard drives to a bigger hard drive when the smaller drives get full. At the moment I am using a portable usb flash drive mainly for convenience and portability, but eventually this will fill up and I would like to know if there is an easy way to transfer to a larger master hard drive later on.
(sorry for the late reply).
You can simply move the work directory to the bigger hard drive (defined in Paperwork’s settings). It contains all your documents and labels.
