I’ve released Libinsane 1.0.10.
- New error code:
LIS_ERR_OFFLINE
: returned when attempting to use the scanner
and the scanner is offline. - normalizers/raw24: fix unpacking of 1bit images (pure black&white).
- New workaround for Sane: ‘hide_source_auto’:
remove sources ‘Auto’|‘Automatic’:
those source behavior depends on the scanner and they cannot be used reliably. - New workaround for Sane + Brother scanners: ‘invalid_page_size’:
some Brother scanners/drivers report there are still pages in the feeder (when there are none),
but when requesting the next page, we get an absurd size (2500x0 for example).
→ in that case, this workaround just ends the scan session properly. - dedicated process: do not try to log messages through the log socket if one of the socket has just died
(happens if the master process crashes) - dedicated_process: disable backtrace support when another Libc than GLIBC is used
(ex: musl) (thanks to Bernard Cafarelli) - dedicated_process: fix build with some Libc (thanks to Bernard Cafarelli)
As usual, information regarding Libinsane are available at https://gitlab.gnome.org/World/OpenPaperwork/libinsane .
ChangeLog is available here: https://gitlab.gnome.org/World/OpenPaperwork/libinsane/-/blob/master/ChangeLog .
