I have directories of collected PDFs, which I import in bulk.
Is there a way to apply the same label to each during import?
Thanks,
Kent
- if you’re familiar with scripting, you can write your own script using
paperwork-json
- if all the documents are similar enough, you can try relying on label guessing:
- import a first small bunch of documents (let’s say 10 to 20)
- document menu → use the option “add to selection”
- select all the imported documents
- add the label you want on it + validate
- wait for all the background tasks to end (the background task indicator appears in the top right corner of the main window, only when there are tasks running)
- import the rest of the documents
- hopefully, label guessing will label all the new documents correctly
