Good news everyone ! Today I’ve tagged Paperwork 1.99. It’s what-will-be-Paperwork-2.0-but-is-not-yet-finished. And I would like your comments.
I’ve tagged this version 1.99 because it has reached a point where it is “usable”: All of the main features of Paperwork 1.3.1 are available … they may just not be really stable yet :). It is now my main document manager (in other words, I don’t use Paperwork 1.3.1 anymore at all).
There are also a bunch of improvements compared to Paperwork 1.3.1 (updated 2020/7/3):
- Entirely modular design:
- Pretty much any features can be disabled
- Code is cleaner, therefore contributions will probably be easier (once the documentation has been written)
- You can expect faster and easier improvements later on
- Better performances:
- Command-line interface that kicks ass.
- Semi-automatic bug report system that kicks ass (I’m going to need it …)
- Editable PDFs
- Smaller exported PDFs
- Automatic scan border guessing that … doesn’t really kick ass …
Still missing (updated 2020/7/5):
Advanced search dialogTranslations(actual translations will be done in testing phase)Welcome documentHelp menuDrag-n-drop of pages inside PDFsMultiple document selectionWindows portageCommands to modify the plugin list don’t handle dependencies yetAutomatic reset of the plugin list when Paperwork is updatedNew version detection + a welcome page/screenText copyKeyboard shortcuts (Ctrl-F, etc)Search keyword suggestionsFlatpak: Popup in the settings when no scanner is found regarding configurationImport on file dropDialog ‘about’Dialog in case of uncaught exception (“unexpected error”)- Code documentation (will be done during testing phase)
- User documentation (will be done during testing phase)
- Search in page: next/previous (#480) (maybe only for Paperwork 2.1)
- Dialog for multiple-scans (maybe only for Paperwork 2.1)
I’ve also fixed a big bunch of minor defects along the way. For instance drag-n-drop behavior is now a bit more consistent ; you can even drop a Paperwork page in Firefox (fairly useless, but meh )
Anyway since it’s a full rewrite, I would appreciate it if some of you could give it a quick try, see if you can find any missing features or bugs.
To try it, the easiest solution is to use Flatpak. You can just follow the usual instructions and replace every occurrences of master
by develop
Please do backup your documents beforehand. It won’t ever delete them by accident, but it will resize down thumbnails generated by Paperwork 1.3.1.
To uninstall it: flatpak uninstall work.openpaper.Paperwork//develop
Thanks in advance,
