Unfortunately, while migrating my infrastructure from Proxmox to K3s, I’ve lost the GPG key used to sign the OpenPaper’s Flatpak repository. I had to rebuild it from scratch using a new GPG key.
This mean that you won’t get any updates until you uninstall and reinstall Paperwork and OpenPaper’s Flatpak repository. Sorry.
To reinstall them, open a terminal and enter the following commands:
flatpak --user remove work.openpaper.Paperwork
flatpak --user remote-delete paperwork-origin
flatpak --user install https://builder.openpaper.work/paperwork_master.flatpakref
