Faild to load module "xapp-gtk3-module" - Appimage
Hi There,
I downloaded the appimage, when I run it with chkdeps it shows me the following message:
Gtk-Message: 20:08:41.609: Failed to load module “xapp-gtk3-module”
(paperwork-gtk:37446): Gtk-WARNING **: 20:08:43.567: Could not load a pixbuf from icon theme.
This may indicate that pixbuf loaders or the mime database could not be found.
Detected system: linuxmint 22 Wilma
Paperwork starts and runs without any problems, but there are no icons like the dropdown icon at the search bar
Any ideas?
Regards Georg
There seems to be a bunch of issues with the AppImage version at the moment.
Unfortunately, I’m currently going through some personal issues at the moment, so I doubt that I’ll have time to fix it before beginning of January :confused:
Actually I had a little bit of time to have a look. It’s fixed.
Sorry for the late repley, but I was offline during the weekend. I will try it.
Good Morning, it works perfect.
Thank you.
