Hi there,
Since a few years I’m a big fan of Paperwork. Because I want to scan all my old documents, I bought a duplex scanner. I looked the scanner up in OpenPaper.work - Scanner brother ads-1700w but unfortunately I’m only able to scan one side.
If I use the Windows 10 Fax and Scan Tool it scans both sides, so I think the driver works fine.
Can somebody give me an hint if its possible to use this scanner directly in paperwork for duplex scanning? Or do I have to use another software to scan and save my scan as a pdf and then import it to paperwork?
Best regard,
Ghgh
