I’d like to have a workflow like this:
- scan document to network share
- have the file server (in my case synology nas) scan and index the document
- use paperwork gui from my notebook (linux) to use the paperwork database
I read that the project is already split into backend and frontend, but I didn’t find any information how to run the needed backend(?) jobs somewhere automatically without the gui.
With the current version, when you install paperwork-backend, you get a shell command called paperwork-shell
. You can use this command to script things the way you want. Unfortunately, the command paperwork-shell scan
comes from the package paperwork-gtk
, displays the scan on-the-fly in a GTK window, and therefore requires GTK (and a display). This is something that has been fixed in what-will-be-Paperwork-2.0.
Hi Jerome and thanks for the answer!
I’m more interested in the ‘import’ command (because the scanner scans the document as .pdf to a file share by pressing the button at the scanner). Does it also need gtk?
Chris
No it doesn’t.
paperwork-shell chkdeps
will show you any missing dependencies (some dependencies cannot be installed using Pip, and some other dependencies vary based on your locale). If paperwork-gtk
is not installed, paperwork-shell chkdeps
won’t try to install GTK.
