It would be great if it is possible to set additional options for the scanner in paperwork.
Rationale: I’m using an ADF scanner (Fujitsu ScanSnap iX100)
- it returns a pagesize of 215 x 859 mm, i.e. A4 paper width and almost 1 m long. This can be solved by the calibrate option, but it saves the large original (~ 3 MB per scan) and takes a long time to process
- The black/white levels are low, so that the image looks like a photograph of the paper, not a clean scan
Both problems can be alleviated by setting scanner options for SANE. Here is a patch which allows to do that from the config file
diff --git a/paperwork-backend/src/paperwork_backend/docscan/libinsane.py b/paperwork-backend/src/paperwork_backend/docscan/libinsane.py
index 16f016b8..fb60d058 100644
--- a/paperwork-backend/src/paperwork_backend/docscan/libinsane.py
+++ b/paperwork-backend/src/paperwork_backend/docscan/libinsane.py
@@ -207,6 +207,19 @@ class Source(object):
# will try to scan anyway
+ extrasettings = self.core.call_success("config_get", "scanner_extra_settings")
+ for (setting, value) in extrasettings.items():
+ if setting in opts:
+ try:
+ opts[setting].set_value(value)
+ except Exception as exc:
+ LOGGER.warning(
+ "Failed to set scan setting " + setting + "=" + str(value), exc_info=exc
+ else:
+ LOGGER.warning("No such scanner setting: " + setting)
imgs = self._scan(scan_id, resolution, max_pages, close_on_end)
return (self, scan_id, imgs)
@@ -613,11 +626,17 @@ class Plugin(openpaperwork_core.PluginBase):
"config_build_simple", "scanner",
"mode", lambda: "Color"
+ 'scanner_extra_settings': self.core.call_success(
+ "config_build_simple", "scanner",
+ "extrasettings", lambda: {}
for (k, setting) in settings.items():
self.core.call_all(
"config_register", k, setting
+ # self.core.call_success("config_put", "scanner_extra_settings", {'brightness' : 20, 'contrast' : 20})
def chkdeps(self, out: dict):
if not GI_AVAILABLE:
With this line in my config file, both problems are completely alleviated:
extrasettings = dict:brightness=int:20;contrast=int:20;page-height=float:279.364;page-width=float:210
I couldn’t manage to add the GUI settings for a good solution, though (inquiring libinsane for all options, creating buttons etc.), that was over the top of my head.
