sigh, this is running develop
O ] [openpaperwork_gtk.widgets.progress] Task ‘thumbnailing’ has ended (0 remaining)
[INFO ] [openpaperwork_core.docscan.libinsane] [LibInsane] …/subprojects/libinsane/src/bases/sane.c:L364(lis_sane_list_devices): Sane: list_devices(): 0 devices found
[INFO ] [openpaperwork_core.docscan.libinsane] 0 devices found: []
[INFO ] [paperwork_backend.docscan.autoselect_scanner] Scanner ‘None’ not found
[INFO ] [paperwork_backend.docscan.autoselect_scanner] Available scanners: []
[INFO ] [paperwork_backend.docscan.autoselect_scanner] Selected scanner: None
[INFO ] [openpaperwork_core.docscan.libinsane] Looking for scan devices …
[INFO ] [openpaperwork_core.docscan.libinsane] [LibInsane] …/subprojects/libinsane/src/bases/sane.c:L311(lis_sane_list_devices): Sane: list_devices() …
[INFO ] [paperwork_gtk.mainwindow.docview.pageadd.scan] Scanner sources: []
OK, I installed the git/virtualenv version, it’s working. I’ll keep checking flatpak occasionally.
Thanks,
Kent
I’ve tested the branch master
with a Ubuntu 20.04LTS freshly installed in a VM, Flatpak and a Brother scanner. For me, the instructions work fine.
